MIHELA
So I have everything installed in my truck ready for break in. I have fuel, computer is sending a datastream. I receive an RPM signal during cranking. I have the distributor from my 76 engine converted to a 7 pin HEI module. I am using a lockout kit for the vacuum advance and weights and new 368 pickup coil. I have a new ignition coil and cap. Ground strap is in place. I have verified voltage in crank and run, all my connections to the PCM have been checked end to end. The module was tested good at a parts store. I am getting no spark at all, even at the coil terminal. What am I overlooking?
