El Diablo
- Apr 25, 2013
- Location
- Yuma, AZ
- 1959 Cadillac Sedan deVille
So, my old buddy LeeRoy was a machinist in the Navy, and now he does high performance engine machining on race cars. He says the cast iron caps on a cast iron block are sweet because all the iron expands at the same rate as the block heats up. He says Steel main caps can be a bitch because they expand at a different rate... If I have a guy copy a set of 472 main caps in 300M alloy, then heat treat, and then cryo-treat, I would have a fancy set of main caps to go with my ARP main studs on my new 472. Anyone know if the rate of expansion on 300M steel is close to the rate of thermal expansion on Caddy 5200 iron blocks?
Regards,
Roy who dances with 472
If he can do main caps from scratch, what about a complete block girdle similar to the 6.0 Powerstroke diesel block?
